I bought a Kingston 512mb SD card, and when i try and fit it into my gage it doesnt fit? I thought about breaking the holders, would that work? I could just use some blu-tack to hold it in then?
Thanks. 😎
Thanks. 😎
No, it will not work. Devices that support SD can also handle MMC, but vice versa is not true. The N-Gage has support only for MMC cards. SD cards are thicker (as you discovered), and more leads for additional functionality. Return or sell the SD card to somebody else (or use it with some other device) and get an MMC card instead for your N-Gage.
Ok,
Ive sorted out the main problem, the card now fits, but guess what, it doesnt work. Any ideas?
Ok, thank you very much.
