a1000 vs 6630!
7 replies · 2,457 views · Started 08 December 2004
Whats ur thoughts? I would say a1000. It looks much nicer and has stereo speakers + much more! Write an opinion.......
Nokia 6630 is way better. I think. I spose every 1 has different opinoins.
ITs got loads of extras! Loads of Freeware aswell!
The 6630 is your regular Series 60 Smartphone on steroids - fast processor,1.3MP camera,3G,Stereo Output but i don't think it can be compared to any UIQ device because it lacks in one major area - input.UIQ devices are touchscreen enabled and that gives them the edge in couple of areas(business,gaming).Unlike SE UIQ phones,the A1000 is not crippled with that jog dial thing and has enough hardware buttons.The only "feature" i dislike is the proprietary memory expansion - Triflash and the fact that the device is made by Motorola :redface:
GhostDog wrote:The only "feature" i dislike is the proprietary memory expansion - Triflash and the fact that the device is made by Motorola :redface:
Call yourself "AAS Super Moderator" and you have brand bias?
Shame on you!!!
I call myself "the chick magnet" but that is not the point here.
Motorola haven't released a decent device in years,somehow they always manage to screw up a great concept.Take the A1000 for an example.It could easily kill the P9XX series if it supported some standard memory expansion like SD or MMC and if you didn't have to da a procedure complicated as brain surgery just to install apps on the memory card.
Guest100 wrote:Call yourself "AAS Super Moderator" and you have brand bias?
Shame on you!!!
Where is it stated that moderators can't have their own opinions about things? Certainly it must be permitted for any individual be it a guest, registered user or moderator, don't you agree? This is a discussion forum, after all.
racerace1 wrote:Whats ur thoughts? I would say a1000. It looks much nicer and has stereo speakers + much more! Write an opinion.......
A1000 is a real PDA phone with 3G network but is cheaper than the P901, the function is better that P901 too. The only restriction is the apps cannot be installed into the internal memory and the supported application for A1000 is not much because it is still new in the market. Once the problem solved, P901 will be replaced by A1000.
Simon
P901?Do you mean P910?The A1000 will never replace the P910 even if its cheaper.1GB PRO DUOs are widely available,i don't see that happening for the Transflash.Most of the applications that work on the p910 should work on the A1000 the problem is that you will be limited to the internal memory of the A1000.The P910 is supported by almost every major operator in the world,the A1000 is available only on Three.
