Question about .tsy modules
1 replies · 2,323 views · Started 08 December 2004
Hi guys,
i wondered if anyone knows which is the tsy module to load into the ETel server to achieve normal telephony functionalities(voice call making and receiveing, for instance). I should use a Nokia device and testing under Windows. Does anybody have any hint about it??
Thanks everyone.
Luigi
Not sure if this is what you want......
Normal Symbian gives MM.tsy along with SDK.
But MM.tsy had issues with RMobilePhone opening.
Third party TSY like phonetsy.tsy solves these problems.
You should use the apt TSY for the particular device.
