Problem in Loading Audio driver
1 replies · 3,071 views · Started 09 December 2004
Hi All,
I am facing one problem in loading the physical and logical device in UIQ application. Every time i try to load a device, using LoadPhysicalDevice() and LoadLogicalDevice(), it returns with the error code "KAlreadyExists"....... i guess UIQ, while booting, itself loads these devices.......so i just wanted to know that is it not possible to load audio driver separately in my application in UIQ. If possible, then how can i do this???
Earlier i was using techview and in that its possible because techview does not load audio driver while booting.
Has anybody faced this problem earlier???
I would highly appreciate any suggestions on this regard.
Pinky
You're in the wrong forum section. Try the developer section! (I'd like to move it there myself, but wouldn't know what category it should be in :redface: )
