Problem in Loading Audio driver
1 replies · 2,335 views · Started 09 December 2004
Hi All,
I am facing one problem in loading the physical and logical device in UIQ application. Every time i try to load a device, using LoadPhysicalDevice() and LoadLogicalDevice(), it returns with the error code "KAlreadyExists"....... i guess UIQ, while booting, itself loads these devices.......so i just wanted to know that is it not possible to load audio driver separately in my application in UIQ. If possible, then how can i do this???
Earlier i was using techview and in that its possible because techview does not load audio driver while booting.
Has anybody faced this problem earlier???
I would highly appreciate any suggestions on this regard.
Pinky
Hi Pinky,
Sometimes, drivers are already loaded
You can add the condition as
nLoadStatus = Load Driver
if( (nLoadStatus !=KErrNone) && (nLoadStatus !=KErrAlreadyExists))
go ahead
I guess its fine doing this.
