Nokia 6670 Setting Wizard
5 replies · 3,765 views · Started 10 December 2004
Is the settings wizard really required? wap, etc. settings are done thru SMS, and what else is there to be set? 900/1800 and network/roaming also goes auto AFAIK.
If I am wrong, should I now run the settings wizard? All seems quite OK.
No, its not really required. But if you have nothing setup ... the Setting Wizard sort of makes things easier for you.
Btw ... the settings are send as OTA (Over the Air) messages, not SMS 😃
Run the settings wizard if you have nothing setup yet ...
Yah. I've downloaded the setting wizard for Nokia 7610 but its a bit different because it does not have settings for my country (Philippines)...
on my 7610.. it didnt have settings for my country (Pakistan) although nokia have stated that Pakistan will be the second largest market in the world for their mobile phones by 2007.. and they havent even made a website for my country! 😞
