"unable to start the application"???
2 replies · 1,707 views · Started 10 December 2004
i've noted that in installing new 9500 softwares, upon opnening the software i would experience "unable to start the application", would any of you guys knows what it means??
does it mean that the software isnt compatible with the 9500 or there are application software that's needed to be installed first?
would appreciate your inputs. thanks.
I had this message only a couple of times when I installed and tried on the 9500 programs for the 9210.
Peace
P.
matrixxx wrote:i've noted that in installing new 9500 softwares, upon opnening the software i would experience "unable to start the application", would any of you guys knows what it means??
I had that problem with OLP programs like the game "Fairway". I re-instaled the OPLreader program and now it's working OK.
