Hey Guys,
I own Nokia 7610, which has 8 MB internal memory,as u already know. And externally I installed 256 MB RAM. When I send any file lower than 4 MB via Bluetooth to my friend's 7610, it transfers fine. But If i try to send bigger file than it, I get message "low disk space" or something like that...so what I guess, that nokia must be storing that file in temp folder of drive C, before it transmitting via bluetooth.. Or maybe, mobile to which i am transferring the file has low disk space on main Drive, where usually bluetooth files must be getting stored. I am not sure about it.. But can anyone tell me, is there anyway to change mobile's default behaviour, I mean, can i change my default temporary folder to memory card...is anyone has idea how to do it? Thanking You..
Temp Folder
go into messaging, then options -> settings. go into "other" and then change the "memory in use" to your memory card. that should work.
-Nay
Yes, but I heard that creates other problems - one of them being it fails a backup.
and u cant even change the directory with FORWARD if u receive it in the memory card inbox.. and yeah it says memory low when u send very large files.. 😞
zainman wrote:and u cant even change the directory with FORWARD if u receive it in the memory card inbox.. and yeah it says memory low when u send very large files.. 😞
Even I faced this issue couple of times ..
i use handyfile for this now.. GREAT software indeeD! moves files no matter how big they are..
