Theme for Sendo X: Silver Aqua v1.0 Beta
15 replies · 11,411 views · Started 12 December 2004
SILVER AQUA THEME FOR SENDO X v1.0 Beta
GOOD NEWS: mendocino have modified the 'hexes' for me so that now you will be able to use this theme along with any other themes! (e.g. you can have the Silver Aqua theme with the MSN Blue theme, so now you will have two more themes to choose from on your phone!)
The zip file is updated! Just install as described below 😊
Hi Everyone,
This is my second theme, which I think is much better than the first one. The name of this theme is Silver Aqua, since its main color is silver. This theme is not perfect yet, but I hope you guys will like it!
The screenshots and the files necessary to install this theme are attached.
The instructions to install are as follows:
NOTE: BACKUP YOU PHONE AND MAKE SURE YOU HAVE THE LATEST FIRMWARE BEFORE YOU CONTINUE.
1) Unzip the files in the zipped folder.
2) put the .rsc file in c:\system\data\theme (create if not exist)
3) put the 2 .mbm in c:\system\data.
4) select themedefault from theme menu
I would like to thank mendocino for his short tutorial on how to make themes!
Any questions, suggestions please post in this thread, message me or email me at [email][email protected][/email]
Attachments: scr1.jpg scr2.jpg scr3.jpg scr4.jpg Silver Aqua for Sendo X v1.0B.zip (237 KB)
owichiu wrote:SILVER AQUA THEME FOR SENDO X v1.0 Beta
Hi Everyone,
And here is the modified and installable Version. So you have an additional Theme to choose from.
Happy X-MAS
Attachments: Silver_Aqua.sis (100 KB)
Hi Everyone,
Good work there!!! let's give the X the look it always should have had!!!!!! 😃 :icon14:
This software causes the Sendo X to crash and when you try and switch on again it goes into a power up/power off loop!
:icon4:
owichiu wrote:Do u mean the sis file or my mbm+rsc's that are causing problems?
The SIS Files has been tested by me and several others, no crashes as it does not change the default theme. The MBM+rsc one does it, and MAY crash your phone.
It overrides the default theme delivered by Sendo to prevent crashing the phone due to a faulty theme!
Hi Everyone,
Ok The themes work perfectly but the icons are all mixed up!!
Ive tried all theme themes going on here, including the sis theme of silver_aqua.
Im using a UK vodafone X
X1.63.1.2
8YOH-O1172-4X000
PLEASE HELP!
adamscott255 wrote:Ok The themes work perfectly but the icons are all mixed up!!
X1.63.1.2
8YOH-O1172-4X000
PLEASE HELP!
a screenshot might be helpfull.... :redface:
jmmb99 wrote:I have the latest firmware version and it worked for me. :icon14:
I've use the mbm version.
Just to let you know, the SIS version is already "hex" patched and the theme can be loaded as an additional theme and you can easily uninstall it. So there is no reason for a MBM/RSC version 😃
Regarding themes, the crashing issue may be due in some way to the existing 'live' theme being uninstalled before installing a new one.
If you uninstall the currently 'live' theme on the phone using software before release 60 then there is a chance you might end up with the problems outlined above.
Always install a new theme before uninstalling the previous one.
mendocino wrote:a screenshot might be helpfull.... :redface:
sorry cant get you a screenshot at the mo, but basically i installed the spiro them as i didnt have it orignally and its fine but when i use MSN or SILVER AQUA the menu icons are mixed up ie: msg has the log icon, contacts has the keyboard incon, mp3 has the help icon, profiles has the favourates(diamond) icon which was cool to see lol since its not used on the x. and loads more. the folder icons are ok just the file icons
I have that aswell. I think its something to do with the fact that the themes where made on phones with the latest firmware. For those of us without it, the menu icons get mixed up.
Anyone who has the latest firmware should be fine. It looks like its just us who have the Vodafone Sendo (or none updated) phones that will have menu icon problems unless the theme was developed on a non updated mbm file(s)
yea i made the themes based on the newest firmware, and so I put the notice about installing the latest firmware before installing this theme~ 😊
