TomTom Citymaps and the 9500
6 replies · 3,375 views · Started 12 December 2004
Is TomTom Citymaps f0r 9210 compatible with the 9500? I have had different reports. I have dowloaded the application, which effectively launches a map, but it closes when I attempt to zoom in - Reason: the ubiquitous KERN-EXEC REASON 3. Any suggestions would be gratefully received.
I have it installed on mine, and works with no problems just for your info. I did format due to problems with psiloc program but everything now working without error
I find their website very confusing. There is no option to download or buy a 9500 version of any of their products. Would you have a link that I can use? Many thanks.
The app is just released to existing customers as for now - and is not publically announced yet... That's why you can't find it
Same for me. Kernel-exec while zooming.
Barflux, would you please send me your TomTom program?
I can't believe you can! :P
Tomtom Citymaps is NOT working on the 9500.
1) You cannot use the standard installation program. But on the CD rom you can find citymaps.sis and this file installs fine.
2) to install the maps you have to copy some files to the apps/citymaps folder. (I copied them form my 9210)
3) Citymaps seems to work fine, but if you try to zoom the program craches.
Zoom in and out works only when the maps are being drawn, otherwize TomTom craches.
Move the map up, down, left or right and then quickly press ctrl-M or Shift-Ctrl-M and you will see that you can zoom.
Conclusion:
Citymaps is NOT working well on nokia 9500
