Nokia 6260 mp3 problem
3 replies · 3,466 views · Started 13 December 2004
Does anyone know how to get music from computer to phone i have tried bluetooth but it wont save to memory card? any ideas, any help would be appreciated
Hi!
The two best options (IMHO) are;
1. Put the memory card into a Card Reader, slap it into your PC and bish-bash-bosh! You're ready to drag and drop your way to musical nirvana
or
2. Connect to PC Suite via PC Suite (whether via Bluetooth or cable, it matters not), then navigate to My Computer -> Nokia Phone Browser -> Your Phone (whatever it's called) -> E: and bish-bash-bosh! You're done!
The only thing I don't like about the first option is that if you take out the memory card, even though it is Hot-Swappable, any application moves you've made to different folders will be lost.
Hrumph!
vodkared27 wrote:Does anyone know how to get music from computer to phone i have tried bluetooth but it wont save to memory card? any ideas, any help would be appreciated
The easiest way would be to use Nokia PC Suite 6.4.1. You can use Audio manager if you want, but Nokia Phone Browser would be better for you.
