seeing phone on nokia phone browser
2 replies · 2,066 views · Started 14 December 2004
just upgraded from a 3650 and really like my new 7610. but, the browser is driving me mad!
when connected and on the nokia phone browser, it doesn't show my phone, so i can't transfer pics easliy, only by bt, which is a drag cos you then have to move them again into the intended folder.
have downloaded latest pc suite, 6.4.8, which includes drivers for the cable. running xp, sp2. don't know what to do, it's taking the shine off my new phone!
suggestions welcome!!?!
No idea really, works fine for me (as much as PC Suite can ever be fine-chokes on contacts, does not do sms, etc. etc.) You can try uninstalling and reinstalling it, first step. It is really finicky on how you install it, do NOT connect the phone unless told to and it installs some zillion drivers for it. Second step, download the installer cleaner from Nokia to clean uninstall and try another reinstall. Are you installing as admin?
Also look here: http://www.allaboutsymbian.com/forum//forum/thread/28602/
hi sandeep,
connected tonight to synchronise. thought i'd check the browser and it was there! perhaps i hadn't rebooted after loading, doh! thanks for your ideas anyway. feel much happier : )
