when i configure my 9500 to do a SYNC using blue tooth.... it always fail.
i had my contacts, calendar and to do list in my outlook and i go to the CONTROL PANEL --> SYNC.... change the setting to SYNC via BT.
but always get an error message "cannot read from c:\system\data\calendar".
i checked and the file is there.
anyone managed to get the BT sync to work?
thanks.
Boon-Tiong Lim
i can.
try to sync using the cable first. if it works, then turn on bluetooth,
configure it and try again.
that way, you eliminate bluetooth problems from sync/outlook problems.
just my 2 cents.
hth.
cheers,
--will
Got the same problem with cable or bluetooth, but sync works when you activate it from PC Suite
Ari9500 wrote:Got the same problem with cable or bluetooth, but sync works when you activate it from PC Suite
i've you find the solution to syncro?
Does it work
for me i can't sync my calendar
