I've been read tutorial about "How To Take Nokia 6600 Themes Apart" but i have a problem.....I'm new nokia 6600 user...i've been download many themes from internet, it's a SIS file, i've been to un-sis then file and i get 2 file.....i've try to use MBM Wizards but i cann't it's "Not a valid Archive" Could somebody help me ? if i done with MBM Wizards, what should i do to upload my theme to my mobile phone ? is there need any software ? if so, can you give me the link to download ?
If I want to install a program to my mobile phone what should i do ?
Teach me please.....
Thank you
Regards
Hendy
Hi hendy,
You can send the files to your phone via bluetooth or ir or just download the themes directly from the site via wap.
There are many posts regarding pc connections in the forum so search for your ideal solution.
Why do you need to unmake the sis file?
The reason you get the error in mbmwhizard is simply because you have a faulty mbmwhizard program (there are a few going around).
I have a working version of it,but im not sure you actually need it to answer your questions above. 😊
Hi Elton....
Thank you for your advice.....I've been try to move my SIS file to Images Folder, but when I browse from my mobile, I cann't found this file. In my mobile there a Theme folder, how can i copy this file to this folder ?
Thank you
Regards
Hendy
Dear All,
Sorry for my question I'm really a new user......I've try copy my SIS file to a folder, I'm search this file from my phone into that folder, I cann't find it....then i double click that file from Nokia PC suite, I cann't find the theme in theme folder....
After that when i try to connect my phone to Nokia PC suite, There is a error "Extended File Manager call Failed" what happen ??? When i click OK, only Root Nokia 6600, sound File, Installation ana Java File and Other File......I cann't browse my phone memory and my MMC...Help me Please.....
Regards
Hendy
The reason the themes are not in the themes menu is because the theme needs to be installed on the phone before you can use it.
If you are using pc suite,just connect the phone and double click the .sis file and it will send and automatically install on the phone 😊
Or just send the file to the installation folder and install it through the built in 'manager' app.
Or just right click the .sis and Send to/bluetooth/nokia 6600 ,the phone will then receive the sis file as a message,open the message and the 'manager' app will start and install the theme for you,the message can be deleted after install.
