Hey all,
When attempting to move some image files from memory card to the phone memory, my phone got frozen and unable to use any applications. I was unable to switch the phone off except by pulling off the battery.
When re-switched the phone, it is not starting up. It just shows the Nokia logo and then blank screen with the background light & stops.
I guess the phone memory is full and the phone is unable to start up.
Any idea on how to reset or delete the phone memory?
Any magic shortcuts to delete files from phone memory?
It seems similar problems occured with other Nokia phones, anyone found a solution?
Please let me know if you have any tips on this or solution that has been proved on other phones.
Hi
I have the same problem with start up of my phone.
when I turn it on the nokia logon appeare and then after that a white backgrownd appeare,
Please If you have a solution send any note for me.
my e-mail : [email][email protected][/email]
Regards
Rami
I went back to the supplier and had to format phone memory. Now it is back to normal. I am abit more careful in transferring files and pics/vids now.
Luckily I had all the info backed up in my pc the day before phone crashed.
The only solution is resetting the memory by formating it.
Good luck.
Shofaan
shofaan wrote:I went back to the supplier and had to format phone memory. Now it is back to normal. I am abit more careful in transferring files and pics/vids now.
Luckily I had all the info backed up in my pc the day before phone crashed.The only solution is resetting the memory by formating it.
Good luck.
Shofaan
This is my tale:
It was a beautiful day when i was playing Prince of persia..then i pressed on the exit button,but it didn`t respond,so i pressed the menu button and FEexplorer-->option-->rerstart-->yes...and boom..it all white and light,just like the torch..i didn`t know what to do so i left it and went to bed,finally this morning when i woke up,the light has been gone out,but when i hold the power button for 3 secs as usual..it light up in 2 secs and the dark came back...
Hope you guys can understand what i said and help me out of this..pls..thx soo much...my dad could kill me if i cant fix this >_<
shofaan wrote:Hey all,
I guess the phone memory is full and the phone is unable to start up.Any idea on how to reset or delete the phone memory?
If you wanna get stuff out the memory u gotta have a data cable and Nokia PC Suite on Phone Browser OK Good Luck
Good luck.
Shofaan
this just happened to me today and im so sad =( i didnt have anything backed up at all
i just bought this phone from india last month
now heres my question...i live in the U.S and i dont know what to do! i contacted nokia and they said they cant help me out since its a phone from india
does anyone know how to reset it by themselves? i would appreciate help!!!
U have to format ur phone using the hard format key.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
I got this problem before. The phone can't boot. So I format my phone.
Be careful when transfering data or deleting data on the phone memory.
Normal Reset (*#7780#) : :icon4: Restores ini files from rom but preserves
user data (photos, 3rd party apps etc)
Deep Reset (*#7370#) : :icon4: This reformats completely the C: drive. All
applications and files stored on this drive will be lost and clean
default files will be rewritten. :icon4:
Full phone format on a Series-60 device
If any of the problems listed below is happening to your phone:
A. Blank screen phone unable to boot-up.
B. Phone is only able to boot-up to "Nokia" screen (may flash "Nokia"
4 times also).
C. Install a program but unable to uninstall it.
D. Unable to delete certain files on C drive.
:icon4: --- WARNING: This will ERASE EVERYTHING on your phone --- :icon4:
If you have any files that are important to you, make backups.
1. Make sure you phone is fully charged.
2. Backup your contacts list and personal files to MMC memory card (if
possible).
3. Switch-off your phone.
4. Press and hold these three keys together
-Green dial key,
-Star key (*)
-Three key (3)
then press the power on/off to swtich on the phone.
Do not let go the three keys until you see the "formatting" screen displayed
5. After a few minutes, the format will be complete. Your 6600 will
now be at its original factory settings.
