Got a prob here.
I installed Opera v6.20 on my Sendo X
Sadly it's a 14 days trial. Now I want the old version back which I got with my X.
Updating with firmware doesn't put back the old version. Anyone know how I can get it back?
Got a prob here.
Just un-install 6.20 - you'll find that 6.10 is still there 😊
(or, do a re-format of the phone (press 5 on startup) - this will reset the phone to it's defaults for that firmware)
stuclark wrote:Just un-install 6.20 - you'll find that 6.10 is still there 😊(or, do a re-format of the phone (press 5 on startup) - this will reset the phone to it's defaults for that firmware)
Gracias
If your trial expires just delete file C:\system\data\ousr600.dat and you will have new 14days 😉
