can you accses msn on 6630 webbrowser?
16 replies · 5,013 views · Started 16 December 2004
I didn't test trough my 6630 browser, but i can go to page with my Pc browser.
I think 6630's browser can do it too.. ill try it later 😊
Anyone got this to work yet. I cant get them through wap or gprs. I've tried the wap browser, also Opera. I've not tried netfront yet.
danidanidani wrote:Anyone got this to work yet. I cant get them through wap or gprs. I've tried the wap browser, also Opera. I've not tried netfront yet.
I downloaded a trial version of Turbo MSN yesterday - logged onto my page and all my contacts were listed .. but no one was on line to see if it worked.
try www.MobileIntTec.com and give it a go - hope that helps 😊
i used the wap mobile msn link for quite a long time now mate but now it doesnt work.. i mean i sign in with the correct password and everything but it still gives an error! and now even the page wont load!
zainman wrote:i used the wap mobile msn link for quite a long time now mate but now it doesnt work.. i mean i sign in with the correct password and everything but it still gives an error! and now even the page wont load!
i went on my pc to www.symbos.com did a search on msn then selected the nokia 6600 section it say it supports the 6630 .. let me know how you get on
Dat1 wrote:i went on my pc to www.symbos.com did a search on msn then selected the nokia 6600 section it say it supports the 6630 .. let me know how you get on
Dat1 i have a 7610 not a 6630 but still that link doesnt even work for me now! :s
Seems every1 is having trouble with msn. Easy solutuion get 'Angile messenger'. Very easy to use and Im not advertising for them.
hope Ive solved some1s problem. Heres mine, my web browser wont work. when i try to go on the internet it says -web: unable to perform operation. Any advice?
yangbludd wrote:Seems every1 is having trouble with msn. Easy solutuion get 'Angile messenger'. Very easy to use and Im not advertising for them.
Wait a month. Opera are soon to release version 7 of their Series 60 browser. I expect it to work a lot better than version 6. They have been working on it for a year, and lately some of the best optimizers at Opera software have been allocated to speed up the develpoment and optimize the code.
Rumours has it it will be released (at least in beta) in March. At least Hotmail will work with this release. I expect MSN too.
if u want to use a WEB-BASED MSN messenger then i would recommend emessenger, the link is something like e-messenger.net
if u want to check hotmail mail i would recommend the reqwireless hotmail checker.. works great and can check mail with using the least amount of data!
