3230 DV-RS MMC compatible?
8 replies · 5,061 views · Started 16 December 2004
Wirelessly posted (NokiaN-Gage/1.0 (4.03) SymbianOS/6.1 Series60/0.9 Profile/MIDP-1.0 Configuration/CLDC-1.0)
Because the 6630 is only compatible with 1.8 volt RS-MMC
There are no pure 1.8V RS-MMC, just the 3.3V older ones and the dual-voltage 1.8/3.3V ones. So, if it is a dual-voltage RS-MMC, it will work on both devices that require 1.8V (like the 6630) and devices that require 3.3V (like the 7610). Regardles of what type of a device the 3230 will be, this means a dual-voltage RS-MMC should work.
But those dv's aren't out yet, for 6630.
DV cards will work in any phone thats the whole point in having both voltages.
As for the the phone im not sure if its out already then it will prob take standard cards.
Normal RS MMC work with 3230,corfirmed with my 3230 i got yesterday,im using a 512 rs mmc (not DV)!!Good news!!!!!
john74 wrote:Normal RS MMC work with 3230,corfirmed with my 3230 i got yesterday,im using a 512 rs mmc (not DV)!!Good news!!!!!
It' s a fantastic news !!!
Could you tell me, please, if the mp3 Audio is Stereo ?
Could you tell me if TomTom mobile works on 3230 ?
Thank you.
