Problem with MMC
1 replies · 1,385 views · Started 17 December 2004
Everytimes i turn on my n-gage it's says:
App. closed :icon4:
Main
Why this?! If i remove the mmc, it will turn on regular!
Is there someone that have some similar problem? Can someone tell me where can i have info about background applications runned on n-gage (as Main, Log Server...)?
thanks!
You probably have installed an app on the MMC, which depends on a so called "recognized" to do something at startup (and for some reason it is now failing; application is buggy, or something has happend to its files, or whatever).
