Small image problem
8 replies · 2,426 views · Started 16 October 2002
Hi all,i'm from Italy. I'm screwed on a small problem: when i have to modify,rotate or open images that are a little bigger than usual,a message appears and it says "unsuficient memory"(maybe the terms are not correct but i'm trying to translate it from italian to give you an idea of the type of message). So i restart my 9210i and only then i manage to do what i have to...This doesn't always happen. :-? I have all these images on my mmc which is a 64mb...not big but ok to start with,even because nokia doesn't produce original mmc's bigger than 64mb. Anyone has an advice or has a similar problem. Thank you in advance. 😊
Hi Dazler,I really apreciate your advice and I thank you for your loss of time after my "problem"! 😊 Do you know where i can download switcher, so that i can start immediatly to get familiar with this software?! I'd even ask you whitch one of the 3 software's you have recommended me is your favorite and the one that best would work on my 9210i. 😃 Thank You very much. The Godfather.
I went from Switcher to appman because appman has a lot more functions but Switcher will do just fine. 😊
http://www.allabouter6.com/software/directory/viewsoft.php?id=270
Thank you very much Dazler!!!Could you just tell me what is that list of apps that you see after opening switcher and switched view?...By the way,it doesn't concern our conversation but have you ever noticed that sometimes the call list in the computer side of the 9210 is listed in cursive instead of bold?Thanks The Godfather. 😃
Never payed any attention to the cursive/bold.
For Switcher you may close everything exept Eiksrvbackdrop. But I personally leave desk and tel open.
:-? ,hi Dazler...strange,I seem to have the same problem...maybe I need to set the program correctly or do some kind of operation I don't know 😞 . Or probably i need to save files that have got to be just smaller :-? ?! Anyway thanks,if you have other advice I'll surely follow them 😃 .Thanks
Godfather.
:s Try to kill more? As long as you leave the eiksrv thing on you should be OK. Al the other apps can be killed using switcher. I hope it works, would be a shame if you have to reboot everytime whn you want to view them.
The easiest way is of course to decrease the image size and resave them ...
