Hiya everyone !!!!
I bought a new brand Nokia N-gage (Normal) as I was very exited but all my fund blew away when I encountered a BLUETOOTH: SYSTEM ERROR. When i try to open Bluetooth folder or Icon I get this error and folder closes.
A day ago I was able to open the folder but automatically the fault appeared. I have not even removed protection sticker from the screen and faced a problem 😞((((((
Anyone help me. i would be grate to you...
I even tried to roll back to origanl settings (factory settings) but no use....
Help pleaseeeeeeeeeeeeeeeeeee
-Rinkle..
This happens when you don't remove the protection sticker from the screen. (just joking)
If you don't have any important data on your N-Gage just format your phone with *#7370# and default code it will ask is 12345.
It will make your phone like you've just bought.
Did you install any applications? If yes, what are they?
the only solution i have ever come across any series60 bluetooth system error is to get the handset replaced.. i hope its under warranty
If you take it to a nokia service center, there is loads....then ask them to see if it is still under warranty, if it is then they will send it away to nokia who will try and remedy the problem, if nokia feel that you have damaged the handset yourself you could be charged. However, 9 times out of 10 they will send you a brand new NGAGE.
Trust me I had problems with an N-Gage and now I have a new one, not the QD but none the less my warranty was extended :tongue:
