Daily alarm
5 replies · 6,305 views · Started 18 December 2004
How do you set a daily alarm for Mondays - Fridays???
Is there anyway other way apart from:-
i. manually seeting an alarm every nite
ii. going into calender and setting a daily reminder
The se K700i has this function
WredDwarf wrote:How do you set a daily alarm for Mondays - Fridays???
This is easy. you can set up a repeating alarm in the calendar by creating a new meeting item. This has the option to repeat the alarm daily, weekly, monthly, yearly etc.....
Is anyone experianceing the Snooze function disapering.
I set my alarm every day, when I dont change the time, I find that I dont have the option to Snooze when the alarm goes off, only Stop.
Firmware bug, there snooze counter is not reset, when you set a new alarm. You have to reboot the phone after you've used up your 5 or 6 snoozes for it to work again. I hope it will be addressed in a firmware update some day (if it hasn't already).
N/A wrote:Firmware bug, there snooze counter is not reset, when you set a new alarm. You have to reboot the phone after you've used up your 5 or 6 snoozes for it to work again. I hope it will be addressed in a firmware update some day (if it hasn't already).
Wow... didn't know there's a bug on snooze
