Installing Fonts on the 9500
6 replies · 5,257 views · Started 18 December 2004
Does anyon know if we can install Font types on the 9500 and if so, how we go about doing this?
Regards
Jass
jass wrote:Does anyon know if we can install Font types on the 9500 and if so, how we go about doing this?
I installed both Verdana and Arial from Windows (you can find them in eg. c:\Windows\Fonts using the commandline) by simply copying them to c:\System\Fonts (the directory needs to be created first) on the Communicator. The fonts improve web browsing greatly (Symbian's font rendering engine seems pretty good compared to eg. Freetype on Linux).
Unregistered... wrote:I installed both Verdana and Arial from Windows (you can find them in eg. c:\Windows\Fonts using the commandline) by simply copying them to c:\System\Fonts (the directory needs to be created first) on the Communicator. The fonts improve web browsing greatly (Symbian's font rendering engine seems pretty good compared to eg. Freetype on Linux).
How can I copy to the C:\system\fonts...... I do not see the c: directory in full on PC Suite. Thanks for helping
sahli wrote:How can I copy to the C:\system\fonts...... I do not see the c: directory in full on PC Suite. Thanks for helping
While in file manager, go the "setting" menu & turn on the "see system directory"
kenkato wrote:While in file manager, go the "setting" menu & turn on the "see system directory"
thanks a lot
How do I change the font on the browser? I've done everything including create the "font" file and copied the font from windows. I have both times roman and aerial.
