6630 as a webcam
9 replies · 5,423 views · Started 19 December 2004
I have seen some software somewhere that will stream the video back from the phone... anyone else seen this? am interested in using the 6630 on its video stand to capture video and bluetooth it to main pc or via other method...
would be pretty cool.. then you could use the bluetooth head set as a remote mic...
sar|n wrote:I have seen some software somewhere that will stream the video back from the phone... anyone else seen this? am interested in using the 6630 on its video stand to capture video and bluetooth it to main pc or via other method...
interesting idea 😃 maybe its workong,but only in 3G 🙄
I thought the Series60 version in 6630 supports one active BT at a time?
If it does only support 1 bluetooth connection, then we will have to forgoe the headset idea... I think I can live with the webcam idea for now. Going to look for "Remote S60 and Softcam"...cheers
I can quite easily listen to music on my BT Headset and send files from my PC to my phone over BT as well as type on my BT keyboard. So thats 3 connections at once...
sar|n wrote:If it does only support 1 bluetooth connection, then we will have to forgoe the headset idea... I think I can live with the webcam idea for now. Going to look for "Remote S60 and Softcam"...cheers
OK, if it doesn't support more than one bluetooth connection at a time I'm quite a lot dissapointed. That means I can't use Salling CLicker at home the same time as I am connected to my HBH-200? Bugger.
willbrady wrote:I can quite easily listen to music on my BT Headset and send files from my PC to my phone over BT as well as type on my BT keyboard. So thats 3 connections at once...
Lol is your phone on charge while doing these?
I think it supports one connection from each type at the time.
For example you can do all of these three but you can't conect to two PC's or can't connect two BT headphones at a time.
Lovely...it works ...almost
Has anyone got this to work using the PT-8 Video stand ?
Ive plugged my 6630 into it and expected the video to be captured from the stand rather then the camera. Was also hoping to use remote s60 to transfer the picture over ... the remote s60 bit works, however the stand seems to do nothing other then charge the phone when connected..
