operator logo
3 replies · 1,630 views · Started 16 October 2002
You have to browse a directory with an image! Go to the image and select Seta as Operator logo! The phone reboots and the logo appears! easy
navigate around the phones folders using seleq as normal, when u come across a picture u like, goto options>file>set as operator logo
I had a folder created in c:\system\apps\ called phones
so the dir looked liek this:
c:\system\apps\phones
i keep all my logos in here as thats where they all are from manually changing it b4 seleq added the operator logo feature
if u dont have this folder created seleq should do it for u and copy your existing pic and resizing it.
