Question Abt Heatset
1 replies · 1,392 views · Started 19 December 2004
Hi ...I am using a BT Headset with my NGage. When headset is on, you won't hear the phone ring only thru the headset. Is there a way to make the phone ring even when the headset is on so I don't need to put on the headset everywhere I go.
glay78 wrote:Hi ...I am using a BT Headset with my NGage. When headset is on, you won't hear the phone ring only thru the headset. Is there a way to make the phone ring even when the headset is on so I don't need to put on the headset everywhere I go.
I also faced a same problem. When someone call u, the phone will not ring (only vibrate if the setting is on). I try so many time and change the setting. Also does'nt work. What the meaning of headset/handfree profile?
Phone : Ngage classic
Headset : Bluetrek G2
Thanks in advance
