Hi, anybody without car radio/cd player/ etc put the N-Gage to works like one?
I want to make mine to be my car player - I have the car speakers, but i dont have anything more. What else I need?
Thanks pals
Thanks pals
je2design wrote:Hi, anybody without car radio/cd player/ etc put the N-Gage to works like one?I want to make mine to be my car player - I have the car speakers, but i dont have anything more. What else I need?
Thanks pals
Hey.
i think you'll need an amplifer. Then you have to connect a 3,5 mm Plug to the Amplifer's input and connect the plug to your phone, if you have the normal N-Gage (not QD) this port must be at the bottom of your phone 😉
Meister wrote:Hey.i think you'll need an amplifer. Then you have to connect a 3,5 mm Plug to the Amplifer's input and connect the plug to your phone, if you have the normal N-Gage (not QD) this port must be at the bottom of your phone 😉
I think this is more like I need. I dont want a visible car player, so an amplifer would be ok. Thanks
If anybody has other Ideas, I apreciate...
Hi!
-Probably you'll need a car charger to ensure your system works a bit longer. 😉
Would some kind of a holder make the "interface" look more professional and have the display on a more visible place? It would also be nice to use the phone for other purposes (like a navigation software), wouldn't it?
