problem with cradle
9 replies · 2,255 views · Started 20 December 2004
hi,
I have a problem with my cradle. It allows connection with PC but don't charge the phone. Is anyone got an idea?
funbidule wrote:hi,
Did you connect the charger to the USB cable? The phone won't recharge just using your computers USB port.
albatorsk wrote:Did you connect the charger to the USB cable? The phone won't recharge just using your computers USB port.
I don't know where I can plug the charger. For me it is charging with usb port . In all ways, The usb cable enters in the charging part of the connector so You cant pllug additional cable
you can plug a charger cable into the side of the usb cable plug, it has a socket for it..
modex wrote:you can plug a charger cable into the side of the usb cable plug, it has a socket for it..
We doesnt have the same cable . Mine doesnt have place for charger
funbidule wrote:We doesnt have the same cable . Mine doesnt have place for charger
Are you sure? The socket is really small.
albatorsk wrote:Are you sure? The socket is really small.
The socket is not small but the usb connector cover the charging connector.
funbidule wrote:The socket is not small but the usb connector cover the charging connector.
What? Yes, the USB cable uses the whole connector on the cradle. However, there is a small socket on the USB-cable where you can attach the charger.
See?
albatorsk wrote:What? Yes, the USB cable uses the whole connector on the cradle. However, there is a small socket on the USB-cable where you can attach the charger.
See?
ok thanks but it stays in red flash and doesnt go to green flash.
This is strange
And then it reboots for charging
