ive been looking around for a while now for a decent office application, (by this i mean word powerpoint etc.) and all i can find is Quickoffice i downloaded the free trial and liked the application a lot but i dont think is worth $50 which is what they are charging for it.
Does anyone know of a decent, simelar application with the abilty to open and create word excel and powerpoint files or just word even that is reasonably priced, ie around �15.
Cheers in advance
Chris
yes i have a freeware for it contact me at [email]removed[/email]
If you have e freeware Office like applications post it here.Since there are no freeware Office like applications,consider this your first and final warning.
No-one ???
QuickOffice is the ONLY office program for series 60!
$50 😮 :frown:
oh well...i'll live
Thanks N/A but i really needed an app that can make these files too aswell as open them
Anyone help.??
Here we go bro, this is what i found and it pretty much matches what you are looking for....http://www.indiagsm.com/master.html?http://www.indiagsm.com/review/freeprog.htm
they are all free so enjoy.... just make sure you post some feedback!
peace,
Jorge
did you check the link i posted???
hi el Chamo yeh ive just cheked the link i like the excel-like micro calc program which i have installed, very good considering its free. all i need now is a program which can write .doc and ive saved my self $50 i can definately live wihout powerpoint on my 6600 😃 😊
thanks and merry christmas to all.
chris
