Browsing Frame Pages On 9500
6 replies · 2,672 views · Started 20 December 2004
I have a problem browsing webpages that have frames. When I press the down arrow or try scroll downwards, only one frame on the site moves, not the entire site.
Where can I download all the short-cut keys for the browser on the 9500?
Ari
Ari9500 wrote:Hi,
Ari
You can download it from the CD that came with your 9500 - there's a PDF there that is called Nokia_9500_List_of_shortcuts.pdf 😃 RTFM
Ari9500 wrote:I have a problem browsing webpages that have frames. When I press the down arrow or try scroll downwards, only one frame on the site moves, not the entire site.
Click in a free field in the Frame (it becomes a red Border) then you can scroll in this Frame
Fratze wrote:Click in a free field in the Frame (it becomes a red Border) then you can scroll in this Frame
Thanks, I can now get each frame to move, but the main site still doesn't work. The site I'm testing the browsing on is my website. Have a look at it www.agetech.co.za on your pc then try access it via your 9500 and you'll see the problem.
Ari
Ok...I see. Its easy. Move the mouse between the Frames (the Cursor changes to a Double arrow). Now klick AND move to make smaller the top Frame. Use the "Navigation-Stick", not the Arrowkeys.
Fratze wrote:Ok...I see. Its easy. Move the mouse between the Frames (the Cursor changes to a Double arrow). Now klick AND move to make smaller the top Frame. Use the "Navigation-Stick", not the Arrowkeys.
Thanks I'll try that, would have hoped I wouldn't have to resize the framzes though 😞
You could try pressing tab to move to the right frame if you don't want to resize. Once the frame you want to scroll in is selected, just use the pointer or the arrows to scroll.
