When i try to go to the web folder on my qd it starts to connect and then it stops and comes up with the error "gprs not avalible,check network settings." how do i get this to connect to the internet on my phone. also i have tried using agile messenger and that works fine. :icon4: :icon4: :icon4: :frown:
XeLLiN
Get into settings,
Then click over GPRS...from there u will get 2 options....
as GPRS connection for which u need to chose "When needed" and another option as access point,here click on you network operator's GPRS access point..
If you dont know your network operator's access point then you will have to get in touch with your network operator..
Hope that helps... :icon14:
Reply if you have any queries..
