NEED HELP PLEASE!!!!!!!!!!!!!!!!!!!
9 replies · 1,364 views · Started 16 October 2002
Hi,everyone.Well i need help for my N7650.After installing by mistake an application for N9210 the phone is "dead".I take out the battery but nothing happens,just see a white screen.The one before the screen asking for the PIN.Nothing else,just this.Is there a way to fix it without having to go to club nokia?Anyone hear anything like this before? I "ll appreciate any help and advice.
My e-mail :[email protected][/b]
close you phone put in the charger! when the screen goes white and the charging symbol appeears, pres *#7370# and the phone will be formated again! try if this works! You will loose all your data but the phone will work hopefully!
Swith off the phone and put the charher in! Do NOT switch it on! Try the code anyways! If this does not work I am afraid I cannot help you!
To switch off the phone i remove the battery.Then i connect it to the charger and the only that i see is the NOKIA logo at the bottom of my screen.No charging symbol appears even that it's connected.NOTE:THE PHONE IS OFF.
But i try this even when the phone is on but still no charging symbol appears.Any idea?If i use a charger from another nokia model?
No it does not matter which charger u use! Forget about the charging symbol try the *#7370# code! If it does not work I am afraid you have to return the phone to a NSC! 😞
i switch on the phone and after getting in the white screen i put the code.the screen is still white.will i see any message after typing the code?do i have to remove my sim cars to work the code?any other code that maybe work???
You dont have to remove the sim and this process can take up to 5 minutes! however if this does not work then nothing will! Teribly sorry about it!
