Just got my 6630 last week from Vodafone. Was very happy with it as I've gone from a 7650 to 6600 and now to 6630 so am used to the functions and symbian software.
I've had some problems already though!
How are you meant to swap the MMC?
I've swapped it about with the card from my 6600 and both cards worked.
Today though for some reason I can't access any data on the MMC in my 6630, but can access it on the 6600???
The 6630 say 15mb of the 32mb card has been used, but I can't access any images. Phone tells me there are none?
Sometimes it says no memory card inserted although I know there is???
Today l also had the problem where the phone froze/crashed while I was looking through my contacts.
I turned it off then back on and got the error message "Unable to start application. Contact the vendor" Or something very similar. Can't remember now.
I played around with it, and only got it to work by taking out the sim + mmc card.
It booted fine. The put the cards back in and it was back to normal, but now I've lost access to my MMC card???
Thanks for you help!
