Can someone extract original tunes from 9500 phone? I found them pretty nice.
Thanx. :icon4:
9500 original tunes
ortega1 wrote:Can someone extract original tunes from 9500 phone? I found them pretty nice.
Thanx. :icon4:
I forgot how to "SHOW" the Z Drive, once i do that i'll extract the ring tones for you.
Meanwhile here are some edited mp3's for ur pleasure.
hmm i searched this furom and found out with the 9210 u can do it using zipmanager
cant find a way with 9500
the make the rom visible, i tried ++sp & also ++rom but it did not work.
there has to be some way
why did nokia make it so difficult
series 60 all u had to do is install a file manager(which i couldnt find any for 9500/9210)
thanx for help :icon14:
Ismail wrote:hmm i searched this furom and found out with the 9210 u can do it using zipmanagercant find a way with 9500
You should be able to do the same with the 9500. Just install the ZIP manager from the bundled software CD.
I believe with an app called YFTP (not sure, but it is a ftp app) you can also access Z from your PC
Raven wrote:You should be able to do the same with the 9500. Just install the ZIP manager from the bundled software CD.
do u know what the steps are?
i cant get the z drive using zip manager. will try FTP.
Here are some famous "Tunes" in MP3: http://www.kamikaze-master.de/km-mp3-download.php
Ismail wrote:do u know what the steps are?
I'm not sure as I don't own a 9500, but I think you first have to enable the Z: drive in preferences, and then archive the files you want from Z:, and finally decompress them.
u cant enable z (rom) drive through prefrences, only system files. in the 9210 u could open file explorer & type ++sp or ++rom but it does not work in the 9500.
wonder how????
I meant preferences in the Zip application.
did that too, but for some reason, it yet does'nt show.
