Hi, Since i got my Motorola A920, ive been unable to charge the unit and use it at the same time. As soon as i plug it in, it turns off and goes into charge mode. Anything i can do about this?
Rob
Rob
n13astra wrote:Hi, Since i got my Motorola A920, ive been unable to charge the unit and use it at the same time. As soon as i plug it in, it turns off and goes into charge mode. Anything i can do about this?
I've had that happen to my A925 once or twice too, but it's not the norm. If you're not using the latest firmware (30.80.20) I would suggest that you have it upgraded as soon as possible. If the phone is still under warranty, Hi3G will do it for free.
albatorsk wrote:I've had that happen to my A925 once or twice too, but it's not the norm. If you're not using the latest firmware (30.80.20) I would suggest that you have it upgraded as soon as possible. If the phone is still under warranty, Hi3G will do it for free.
Ah looks like its a fireware update (30.80.12), but the handset is no longer under warranty so ill have to do it myself. Can anyone link me to the firmware files needed for the update please? [email][email protected][/email] thanks I'm in australia.
