hey all,
i'm using my palm TT for 4 years now. but not long ago i purchesed NOKIA 6670 and since then i'm trying to switch to 6670 complitly...but can't find anywhere disent software for organising my dates,tasks..and so on.
can you give me some tips where i can find some nice software for orginising?..(if there is any of course)
thnx
Edit/Delete Message
Organising on 6670
Suggest you buy another Palm. There is software and stuff, you can check out this site itself, but a Palm is a Palm and a phone is a phone. They are all getting together, but IMO, still a couple of years away.
Otherwise the built in calendar/contacts/todo/notes on the 6670/7610 are reasonably adequate for most people, I guess.
But if you are looking for Palm type functionality, you are better off with Treo 650.
What you can do is try to use PC Suite to sync with Outllook, but more probably than not, you will get frustrated doing this. I am going to try to switch from Palm T|E/Desktop to Outlook/PC Suite/7610 when I have some time, but I will need a strong dose of courage to attempt to unfix what is working very nicely currently.
