9500 Wifi and Apple Airport
6 replies · 3,181 views · Started 21 December 2004
Anyone found a working connexion ?
The 9500 is connected (100%quality) but I cant use the Mac DSL connection neither for emails or for internet ?
I tried ipv4, ipv6, DHCP but cant get through
Mac OS 10.3.7
Airport Extreme 3.4.4f5(3.50.37.p4)
Very sad !
gounin wrote:Anyone found a working connexion ?
Mac OS 10.3.7
Very sad !
I've got my 9500 connected to my WinXP machine, but I can't resolve DNS entries. Can you ping the IPnr of the 9500 from your Mac?
Can you access websites using IP numbers?
The 9500 can see the Mac and gives its name, says that the connexion is 100 quality
But the mac does not see the 9500 by any ways
IP adress and Ping I dont know how to do that
gounin wrote:The 9500 can see the Mac and gives its name, says that the connexion is 100 quality
How do you mean "can see the Mac" You mean "can see the Airport I hope"
Did you check WEP settings. because my 9500 works everywhere where an Airport is, being it Express or Extreme.
Huib
Huib van den Oever wrote:How do you mean "can see the Mac" You mean "can see the Airport I hope"
Huib
I had tons of toruble with my airport and mac and my old rg 1000 and mac.
I ended up creating a new access point on the 9500 and putting ina manual ip address, gateway and dns now it works perfectly.
Mac OS 10.3.7
Very sad !
I have an Airport Extreme at work and an Airport Express at home, my 9500 hooks up to them both with no problems. If you are using WEP remember that you must enter your password in the Nokia internet setup in hex format. Run your Airport Admin Utility, select your network and then select the Base Station menu. Click the " Equivelant Network Password". It will give you a string of numbers and letters. Enter that into your Nokia internet setup exactly as how its shown there. Also make sure your WEP is set to 40bit security. I have my base stations setup with DHCP enabled. Check your settings on both the airport and 9500 so that they both concur.
One more thing, under "Advanced" in your Nokia and in the WEP tab, make sure that WEP authentication is "open" and Key #1 length is "40bits"
Hope this helps. Happy Holidays 😃
Thanks the helpfull informations and for the holidays ! After hours hours messing around I will definitly need holidays to settle this Airport business
