Sms sending icon dont disapper???
5 replies · 1,873 views · Started 21 December 2004
after upgrade firmware france ver. icon of sending sms message dont disappear after send ...thnx for any help
ps:i do 2x hard reset and same story
lout wrote:after upgrade firmware france ver. icon of sending sms message dont disappear after send ...thnx for any help
It sounds like the messages have not gone (still in the OUTBOX?)
Maybe your message centre number is incorrect?
check it here:
Menu / Messages / Options / Settings / Text Message
What message cntre is "in use" and what are it's details - name / number.
These may not be set correctly for some reason.
Did you "5" the phone after the firmware update?
I did 5 after upgrade 2x i dont have any unsend messages and in outbox message centre its ok in stings i have Message validity Maximum time so what now ???i will try upgrade again so maybey its help
lout wrote:I did 5 after upgrade 2x i dont have any unsend messages and in outbox message centre its ok in stings i have Message validity Maximum time so what now ???i will try upgrade again so maybey its help
Can you describe the icon for me? Is it the envelope icon (unread message) or the "arrow going up out of a tray" icon (outgoing messgae) or something else?
Also, are you sure it is for SMS - e-mail or MMS also use the same icons...
pk
Sounds like it's fixed...
For everyone else...I had this when I updated my firmware (this was TO 50C)...for whatever reason, the phone got confused between the SIM message centre and it's own settings for the same message centre...hence messages weren't being sent.
A quick Settings > Text Messages > Service Centre check sorted it out though...always make sure you're using the SIM message centre unless you know a good reason not to be!
