I've download PC suite 6.41. I've sync everything exept my calendar. It doesn't work
Someone have the same problem?
I have the new PC Suite version as well, but no problems with calendar. Did you make sure in Sync properties that you've defined all that you want to sync?
I tried again but always the same message the client sync ML don't answer
It works only for my contacts
And with the old version pc suite 6.4 it was worse. No sync at all
tkao2025 wrote:I have the new PC Suite version as well, but no problems with calendar. Did you make sure in Sync properties that you've defined all that you want to sync?
francois8500 wrote:I tried again but always the same message the client sync ML don't answerIt works only for my contacts
If you have all the data in your computer, do the next steps:
Stop calendar process (ctrl/shift/chr + K)
Rename the old calendar in filemanager default\system\data for old_calendar and move it to the MMC
Restart the calendar
Now try to sync again
If this doesn't work...
Go to the sync-program and /menu/tools/Reset PC Suite profile
Now try again... This worked for me atleast
