How do i make Remote S60 work with my IrDA and N3650
2 replies · 3,486 views · Started 22 December 2004
Hi All,
I am trying to configure my Nokia 3650 to be remote controled via PC using
RemoteS60 software.
How do i configure to use it wth my MA-620 Infrared Device and my Mobile
i am not able to work it out.
Please let me know
You have to check the box next to Infrared in MRouter after connecting Nokia 3650 with the computer via IrDA to make Remote S60 work.
Usually MRouter comes with PC Suite or you can download it from
www.intuwave.com
After connecting phone with Mrouter, open Remote S60 in phone. From Options->Infrared->Serial(IrCOMM) (I chose the last step as this option works with me).
Now open Remote S60 on the computer. Click on "start" to begin
If you have followed what's written above, I guess Remote S60 should be working by now.
rohitkhannak wrote:You have to check the box next to Infrared in MRouter after connecting Nokia 3650 with the computer via IrDA to make Remote S60 work.
www.intuwave.com
Well i will give it a try , Sorry for the late response i had my exams
