Birthdays?
4 replies · 2,074 views · Started 22 December 2004
I got a question.
If I add a birthday to some of my contacts, it won't show in the Calendar. Am I doing something wrong or is it simply impossible?
I was afraid of that. Well, not much of a problem, I just added them all to the calendar. At least glad that that is possible (unlike the P900, where you had to buy a special app if you wanted to save some birthdays 🙄 )
Delta737 wrote:I was afraid of that. Well, not much of a problem, I just added them all to the calendar. At least glad that that is possible (unlike the P900, where you had to buy a special app if you wanted to save some birthdays 🙄 )
Delta,
If you put your the birthdays of your contacts in Outlook, Outlook automatically puts them in the agenda, so also in your 9500 agenda. Works great 4 me!
Regards
Thanks, that IS a solution indeed. But I don't use an Agenda (like Outlook) on my PC. I just added all the names to "special dates" in the Calendar, worked for me!
