What is the best Mp3 program that is compatible with the 3650?
What would you say is the best Mp3 Player
there are 2 i know and i use - Mp3Go and Ultra MP3
the audio quality is same i feel but if you want more visual with skins
then go for Ultra Mp3. mp3 go has simple interface.
both support id tags
SymbianGuru wrote:there are 2 i know and i use - Mp3Go and Ultra MP3the audio quality is same i feel but if you want more visual with skins
then go for Ultra Mp3. mp3 go has simple interface.both support id tags
i couldnt care about skins so that won't afffect me. Well I have the latest Ultra Mp3, so I'll use that. When I want to put songs onto the mmc, how would I do it, and will I need to make a folder?
Well just create a folder called mp3 or any name on your mmc and dump all the
mp3s into that folder and then start ultramp3 and just scan the mmc using
ultramp3 player and thats it all the songs are shown in the playlist
cheers.
duffers wrote:What is the best Mp3 program that is compatible with the 3650?
I dont now the quality of sound, not yet, but the SKIN:
:icon4: Ultra Mp3 SKIN:
GOOD :icon14: :
- Has 3 skins;
- Easy to change the settings;
- The display its complet;
BAD :icon13: :
- Small Letters;
:icon4: Mp3Go:
GOOD :icon14: :
- Easy to used;
- The setting is not BAD, but not goog!;
- Simple Display;
- Autolock keypad after xx minutes;
- Bad :icon13: :
- Its simple, put play the sound very well!
* I dont test a lot the players!
** For me its the same thing, play the music that i wont, when i wont! 😃 😃
Just notice the quality of the one and only DivX/XviD player for the 3650, The SmartMovie by Lonely Cat Games, and you'll surely know what quality you can expect from their Mp3 player - the Ultra MP3. I'm using it, it's the best.
TIP: Have you noticed, that when editing the playlist in UltraMP3, you can mark/unmark currently selected title with the Pen key ?
