Anyone know of any free software or some other method to create your own themes on the P910a? The one on the Sony Ericcson site doesn't work for this phone and the only other one I can find is from Vito software and they want $25 for it. :icon13:
Any help is appreciated. Thanks.
Vito used to be free for personal use(look here: http://www.allaboutsymbian.com/forum//forum/thread/19973/).
Are you sure it isn't anymore (if you just use it for personal use)?
No it's not. Maybe it used to be. Here is the new link: http://vitotechnology.com/en/products/themeeditor_p900.html
There must be another way.........Vito's isn't even that good if you ask me; it doesn't contain even ONE choice of buttons or anything. Just comes with one template. Doesn't matter because they are charging too much for it anyway.
