Hi everyone
i'm new at this forum
i would really appreciate it if someone could tell me about a program to forward themes existing on my phone (7610) to other symbian phones by bluetooth.
any app to send themes from phone to phone?
i think you can go into the Application Manager, fine the theme there and send it throguh bluetooth, i think that is it! if not then sorry for the wrong info!
KaZ wrote:i think you can go into the Application Manager, fine the theme there and send it throguh bluetooth, i think that is it! if not then sorry for the wrong info!
nah that doesnt work
but i have SeleQ and if i use that wat files exactlly are the themes files and where r they located
No. Appl. Manager does not handle themes, it is through themes. But I do not think you can send an installed theme directly to another phone. It puts its components into different folders. You need to also save the .sis file manually, which should then be able to be sent in the normal way.
