Thanks!
How could I mass-move all the clips in Inbox to the Memory Card?
I forgot to say that I got Nokia 6600 and I got SeleQ installed.
No one knows!
smokee wrote:No one knows!
if you got any solution pls email me bcs i am wondering too of same problem.
thanks in advance.
email: [email][email protected][/email]
If you would have explained your question further, it would have made more sense to me.
If you are talking about copying everything in your inbox in your phone memory to the memory card memory, use the following method-
Open SeleQ, go to E:/System/Mail, and delete everything in that folder. NOTE: any messages saved before in memory card memory will be deleted this way.
Now open Messaging, Options->Settings->Other->Memory in Use-> (the name of your memory card).
The phone will prompt you, "Copy all messages to new message memory?" Choose yes, then it will prompt you "Save original messages?" Choose Yes or no if you want to save all the messages in the phone memory or not AFTER they have been copied to the memory card memory
Now all your messages should be there in the memory card memory.
