I have got a 7650, tried to IR images from it to 7210, and got an error message.
Is it because 7650 and 7210 are not compatible?
it's impossible for the moment
the 7210 work for ir with the pc suite 50 if you want to put a images on the 7210 take be the 7650 put the 7650 image on the pc and with the pc suite put the 7210 with the nokia image converter on pc suite 50 and download the image now you have on your 7210 it's the only thing
i think it all has to do with 7650 being symbian and 7210 being series 40, those 2 yet not compatible for image transfer, my 9210 also couldnt send to the 7210, a message came up on my 9210 saying "Other phone does not understand format" or something like that however contacts transfer works for me from 7650 to 7210 or vice versa
