Hi, I ordered the Sendo X @ Expansys but wanna know if the headphones socket in the phone is 3,5 mm (usual) of 2,5 mm socket (N-Gage size socket)...
Because the package with the phone doens't consists a 3,5 cocket converter, I thought it would be 3,5 mm...
Anybody knows???
The headphones socket is 3.5 mm I haven't tried my N-Gage headset yet. Gonna try it later and can then tell you how it works out.
Ow yeah, that was all I wanted to know prudent :icon14: ,
cause with the N-Gage you must first connect a cnverter (3,5 to 2,5 mm) and then the headphones - and I want quality so I got Sennheisers, in stead of those earphones which don't stick in my ears (only for 5 minutes).
prudent wrote:The headphones socket is 3.5 mm I haven't tried my N-Gage headset yet. Gonna try it later and can then tell you how it works out.
When has Sendo changed the socket? My X has a 2,5 mm socket.
bottomline: I meant 2.5 mm but RobinGugelot understood it, so it turned out good anyway. I hope it works too. Haven't had time to check it out yet.
prudent wrote:bottomline: I meant 2.5 mm but RobinGugelot understood it, so it turned out good anyway. I hope it works too. Haven't had time to check it out yet.
What is it...2,5 or 3,5...cause u ain't getting a converter when u buy the phone right??
Cause I use my Sennheiser headset
The headset socket is 2.5mm. You are going to have to use a 2.5mm to 3.5mm headphone adaptor to use your own headphones.
omegax wrote:The headset socket is 2.5mm. You are going to have to use a 2.5mm to 3.5mm headphone adaptor to use your own headphones.
Does the sendo x come with a 2.5 to 3.5 adapter im getting it from expansys if it matters
No. It doesn't come with a 2.5 to 3.5 mm adapter. You have to get it from somewhere else.
psittacosis wrote:Does the sendo x come with a 2.5 to 3.5 adapter im getting it from expansys if it matters
