I'm wondering if anyone else has a similar problem. I have my 9500 setup to search for my Home WiFi, then my Office WiFi, then any WiFi and finally GPRS. I have the roaming setup so that it will ask me before switching connection.
When I try to send an email, if the default connection (Home WiFi) is not available, it will ask me to select another connection. I select GPRS and the sending fails with a message that says something like "Message sending failed. Please check your email settings".
The weird thing is, when the default connection is available (in my case Home WiFi) or when I set the default connection as GPRS, it will send the email without any problem! Something isn't "carrying over" as you switch connections from default.
Any suggestions? Help....!?
Btw, Merry Christmas! 😃
