Bluetooth Problem!
5 replies · 2,349 views · Started 25 December 2004
Dear,
I have a problem with bluetooth,When I want to send a file that it's size is >2MB,
This message appeared: Not Enough memory to perform operation.Delete some Data First.
I have a 128MB mmc with 50MB free space & about 2.5MB of My phone Memory
is free also.
I use the latest firmware (FW15).
Can anyone help me?
Hi, i did have same problem. You are sending 2mb in phone memory not to MMC. The phone cant unpack such big file but if you send it to MMC then you can open and run that file.
Good Luck!
Lauri
e-mail lonely525hot.ee
Dear,
How Can i set that?(In use Memory : Phone Memory or MMC) for
messages(Bluetooth or,...).
I can't find any option in SX1,I find this option on Nokia 6600 but in SX1 at same
place i don't see this option.
You must use the tool called MsvDriveE to send files larger than 2 mb. You'l find the tool and instructions somewhere on this site
memarian wrote:Dear,
is free also.
Can anyone help me?
the file must less than the phone memory!!! IF you want to send the file large than the phone memory,that it appears Error!!!!
