Trying out my ne A1000 I managed to block both PIN1 and PIN2. 3G was able to provide a method and a PUK1 to unlock PIN1 but not for PIN2. Can anyone help how to unlock PIN2?
PIN2 blocked.
Sorry for the inconvenience, however, I found the answer (3G could not help and suggested to buy a new SIM card).
For others' benefit:
If PIN1 is blocked then enter **05* into the phone keypad. It will take you to the PUK1 entry screen.
If PIN2 is blocked then enter **052* into the phone keypad. It will take you to the PUK2 entry screen.
Type 14920000 into the PUK entry screen for both PUK1 and PUK2.
Next it will ask for the new PIN1 or PIN2 and the problem is solved.
